I have a very nice start for a drag car or restoration. 1973 V8 car with factory disc brakes. Car has small bolt factory a body 8.75” rear end with a 489 2.76 open carrier. Needs a floor pan and most of the interior. Has USCT sub frame connectors and I do have the front bumper and brackets although the front bumper is not show quality. $6500 and can deliver to the Indy swap meet with a deposit. Tires are also new but 14”. I also have many other motors/transmission combos if needed. The car is overall very solid but is not perfect. There are nominal dents on the sheet metal and has minor rust that will need repaired or drive it as is.
