[WANTED] 1973 Plymouth Duster Fan Shroud #3673820
Deckard12
Blanchard
Rating - 0%
0   0   0
I am looking for a Fan Shroud for a 73 Duster with a 318.
Measurements: 25 3/4 L center mount to mount, 12.25 height center mount to mount
Core Measurement: 18 x 24 roughly
I believe the part number is: 3673820
And looks like this.
Thanks.
Should be the same. but I will double check it for you tomorrow and send you a pm.
I have one also - #3691909 ... if Blanchard OK... i am about 4 hrs from ya
Not sure if tape measure shows it very clearly but it is the dimensions you put in your post
It was removed from 74 Dart Sport with a 318
