Mr73Plymouth
New Member
I have a 1973 Plymouth Scamp/Valiant for sale.
318 LA small block w/ 904 3 speed trans, both are out of my Aunts 72 Dodge Demon with 60k miles.
Mopar Purple Shaft cam (I don't remember the lift or duration but it's the biggest cam I could use and able to keep the stock 318 heads)
3,500 stall converter, headers w/ X-pipe. double timing chain and gears, Edlebrock 4brl carb. 620 CFM if I remember right??? Superstock leaf springs on the back. New master cylinder and power break booster, new rear wheel cylinders. Theres probably more little stuff that I've done here and there over the three years I've owned the car. It is my daily driver, has great vacuum psi and oil psi! Runs awesome! The interior is pretty much all there! Id say 97%, does need some holes patched in the floor, needs new carpet and headliner. Also needs both front fenders and rear quarter panels. It was originally dark brown w/ a vinal top and a slant six car. Someone did a 318 swap and did a horrible job, I got my Aunts engine and trans and put in. I really dont want to let this go because it is my first project but for now I think it needs to go unless I can get my priorities figured out and can hang onto it, but for now its up on the market!
I also have videos on YouTube of the first few starts and breaking in the new cam, it smoked alot at first because the engine sat for about 10 years. Search Mr73Plymouth to view the videos.
PRICE: $4,500 OBO
Located in Central Michigan.
Thank You!
PRICE: $4,500 OBO
Thank You!
