[FOR SALE] 1973 steel crank 440
wannadrag
Waupaca,WI
Rating - 75%
3   1   0
Have a 1973 steel crank 440 from a C body.It is apart but has very little ridge and is std bore.Everything is there and comes with a truck oil pan and 906 heads,cast intake and no exhaust manifolds.I was just going to re ring it so I will include new rings and new rod bearings. $450
Or will swap for a good running small block chevy 327,350,400 pre 1980 with the 4 bolt valve covers. I am located 6 miles northeast of Waupaca,WI
I will trade for whats listed or cash.I had brand x cars before I got hooked on mopars and still have a couple 65 Nova's that I haven't touched in 10 years so the time has come to get them going.
I gottaq 92 GMC 350 hangin on the engine stand. pulled valve cover, pretty clean. rolls over nicely. don`t know any more than that. replaced it w/ a hot 406 sbc for dragracing, then traded the truck off. bad is , I`m in okla.
Tin work,bolts all there just no pics of it
Will swap for a running 318 or 360
I have a good running '83 318 that came out of my wrecked 65 dart. I'd be happy with just the short block & possibly the pan. shipping would probably kill us here (Lincoln Nebraska 68528). are the rings cast or moly? EDIT would you ship the short block?
Local pickup,i do have a 400 short block its 30 over and will need to be bored I will throw in with the 440 for a running small block and trans combo.
