wannadrag
Have a 1973 steel crank 440 from a C body.It is apart but has very little ridge and is std bore.Everything is there and comes with a truck oil pan and 906 heads,cast intake and no exhaust manifolds.I was just going to re ring it so I will include new rings and new rod bearings. $450
Or will swap for a good running small block chevy 327,350,400 pre 1980 with the 4 bolt valve covers. I am located 6 miles northeast of Waupaca,WI
