1974 360
Hemi331
Member
Rochester
I have a 74 360 in my dart, I know nothing about the motor the owner had it built but then he passed on. When I tried to see what heads were on it I see no external markings on the pads near the spark plugs. Just wondering what was available in 74 for heads and if some are better than others. Any help would be much appreciated. Thanks.
Take off a valve cover and get the 7 digit casting number. The heads could have been swapped and the number is positive ID of the head.
If there stock 1.88 valve heads there all basically the same. Good for about 1hp per cid with basic upgrades.
They will have X, J, O or coukd be just a square rasied block. X were 202, Some of my J were 202 some were not the rest were 188. For street 188 is fine. Little clean up meens more
Like stated look under the covers
If they are 74 heads 360 heads they will probably have 1.88 intake valves and 1.60 exhaust. The exhaust valves will have hardened seats under the valves which help them to work better with todays fuel.
I would just drive it for a while before ya start tearing into it.
Post some pics.
Welcome to the site.
* OEM 1974 heads tend to be 3671587.
* 3418915 heads tend to have letters by the spark plug holes and originally have 2.02" or 1.88" intakes, including T/A heads.
* 2531894 were all X heads with 2.02" intakes.
* At some point the casting number was moved from the top of the intake runners (under the valve covers) to the underside of the mouth of the intake ports. i.e.: 4448308. - ('80's?)
*Later heads also started getting the larger pushrod holes. Not sure exactly when that started - ('80's?) May be associated with the transition to OEM roller cam & lifters.
As others mentioned, 1.88" is plenty for street/strip. But it's the age, number of valve jobs and the quality of the valve job that are the biggest factors in performance. A 1.88 can outflow a 2.02. Multiple valve jobs "sink" the valve & hurt flow. Cutting a 1.88 head for 2.02 valves can help air flow because the seat ends up fresh & high in the chamber. "Quality" of the valve job & angles depends on the machinist. Aftermarket small block stainless intake valves have more of a "nail" head and tend to flow better than OEM intakes which have more of a "tulip" shape.
Lots of variables in play.
