I have a 1974 440 short block. It is disassembled and has been in dry storage in my garage for probably 15-20 years. It was acquired with no heads or intake manifold so the bores have some surface rust, but not pitted. Standard bore. Cast crank is std/std, as well. Could use a good polishing or may need to be turned. It was originally in a truck. Has 1851535 LY rods. Water pump housing is off a 1976 440. Main caps are all there, as well as fuel pump rod, and front timing cover. Oil pan is a 933 off a 1976 New Yorker. Asking $350 OBO. Pick up at 49425, West Michigan. PM me if interested. Scroll down for more pictures.
