[SOLD] 1974 Dart Sport
Kiddart1
Macomb Michigan
415 Stroked small block, Motor Purchased thru Indy Cylinder head. Car is very consistent and can still be driven on the street, currently plated and tagged (Insured as well) Car is very easy on the eyes, gets a lot of attention
Motor:
360 Block
Cast Crank (4 inch Stroke)
Eagle SIR Rods
Wiseco Flat Top Pistons
12.0 to 1 Compression
Manley High Volume Oil Pump
8 qt. Oil Pan
SFI approved Balancer
Complete 360-1 Indy Heads (Match Gasket and Correct CC’d by Indy)
Molly Push rods
360 -1 Indy Intake
Indy Solid Hot Street Cam 250/260 dur @.050” 532/555 Lift
1.5 Indy Offset Rocker assemblies
EZ Efi TB injection
TTI 1 7/8 ceramic Headers 3 inch Collectors
Trans:
904 Automatic (Cope Racing Transmision)
Turbo Action Clutches and steels
Turbo Action Reverse Manual Valve Body low band apply
Turbo Action 4500-5000 Stahl Converter
Hurst Quarter Stick with reverse lock out
Drive Shaft Loop
Exhaust:
3 Inch X Pipe with Dynomax Ultra Race flows dumped at rear Axle
Interior:
8-Point Roll Bar
Frame tied
Drag pack Challenger seats
Five Point Harness (Driver and Passenger)
Full Back Seat with Original Covers and Seat Belts
Fire Wall between rear seat and Trunk
Head Liner in great Shape
Dash Pad is excellent
Dash is in great shape(New Auto meter Gages)
Recovered Door Panels (Hand Stitched to resemble original embossing)
Rear End:
8 ¾
4:56 Richmond gears with Yukon 31 Spline Spool
Dutchman aftermarket SFI approved axles (Large Bolt Pattern)
Super Stock Springs
Pinion Snuber
Misc:
4 Wheel Disc Brakes (Large Bolt Pattern)
All new bushing in Front End (Energy Suspension)
Tubular Front Uppers
90-10 Calvert Shocks up front
9 way Adjustable Calverts Shocks rear
28 x 10.5 x 15 M/T Slicks (street miles)
Rims 15 x 8 Sport Mag Wheel (Jegs) Rear / 15 x 3 Sport Mag Wheel (Jegs) front
Lift Off 6 Pack Hood
All glass is in great Shape
Newer Drivers and Drives Rear Floor Pans needs to be neatened up(will work on it)
12 gallon Fuel cell
MSD 6AL Box w/Rev Limiter
10K RPM Tack W/Shift Light (Auto meter)
Battery in trunk
Power cut off switch
New Universal Wiring Harness
Street Legal and Plated
Time slips to prove this is a very fast street car. The car's best time is 10.83 @ 122mph with 1.43/45 - 60 foot times, car weighs in at approximately 3200 lbs with driver. Asking - $17,500 Turnkey.
PM for additional pictures and requests
Car is located in Macomb Twp. Mi, just north of Detroit
Thanks for the add
I had the stripe kit made from a guy who goes by Challenger Gary. its a 72 duster stripe kit longer and without the door handle cutouts. had the door handles black satin to match.
