4 DOOR JUNKIE!
74 Dodge Dart custom 4 door..72,666 org miles!
318 2bbl, ps, manual brakes with disc on front. I will first tell you what it needs as of now. The radiator needs to be re-cored, or get a new one at 1Aauto.com for $196.00 shipped to your door. The rear driver side quarter needs to be cut and replaced. I have this and will go with car. Keep in mind; this is not a full quarter it is only what is needed. The front driver side fender dog leg is in need of repair, and can be repaired by the right person. There is a small dent in front pass side fender and is a very easy fix. There is a dent in the rocker on pass side, again an easy fix. This car is VERY clean!
ALMOST FOR GOT 1 THING...I SHORTED OUT THE ALT GAUGE, THIS WILL NEED TO BE REPAIRED OR REPLACED.
Now what has been done to it........
Complete tune up with Mopar performance wires, NGK plugs, cap and rotor and a new fuel filter. The 2bbl was just rebuilt by Dependable carburetor in Chicago (35th & wood) and they did a damn fine job. I have installed a new ignition switch, starter, water pump, thermostat, hoses, belts and shocks. I also installed a grant GT wheel and tach. I have the org wheel that goes with the car.
I have a set of vintage 14" western rims with almost new tires on them. These DO NOT come with the car, but will sell them for an extra $325.00
Please follow link below for some pictures. I can also email a few more detailed one if needed......let me know.
http://s153.photobucket.com/albums/s225/chitownkracker/?action=view¤t=08f1cdab.pbw
Asking $1800.00 OBO
Thank you all!
Phil
502-817-1462
Asking $1800.00 OBO
Thank you all!
Phil
502-817-1462
