Hello all,
I have a 74 Duster with Cragar SS 15" wheels on small bolt pattern drums all the way around. Currently they have 5/16" spacers with standard mag shank lug nuts. It seems the lug nuts are not long enough to get any more than 1/2" threaded on 7/16X20 studs, seems like a problem. It would appear as though PA has set a limit of 1/4" on spacers and quite frankly I would like to go a little smaller than that, say, 1/8 or 3/16 and lug nuts that are a little longer. If you are running Cragars on small bolt drums what combination, if any, of spacers and lug nuts are you running. Additionally, does Cragar recommend a certain torque spec for these wheels?
