[FOR SALE] 1974 Duster
airkiller
MOPARS Rule
Sacramento CA
Rating - 0%
0   0   0
Here is a list of stuff done to the car during resto
Work Done During Restoration
Engine Completely Rebuilt – Bored .030 over, mild Cam, .010 Over Bearings
New Headman Headers
New Flow Master Super 44 Mufflers with 2.5" Exhaust with "H" Pipe
New Edelbrock 4 barrel carb
New Engine harness
New Alternator
New Mopar Performnce Distributor and Performance Control Box
New Power Steering Pump
New Power Steering Gear box
New Radiator / Repaired Stock unit
New Battery
New Fan and Clutch
New Brake Calipers and Shoes
New Brake hoses and lines
New Front Suspension – PST Poly-Graphite Bushings Completely through out, New PST performance Torsion Bars
New PST Performance Rear Springs
New Steering Column with Tuff Wheel
Rebuilt A-833 4 speed Transmission
New AMT Steel Transmission Hump
New 4 Speed Console top
New Hurst Comp Shifter and handle
New Zoom OEM type upgrade clutch and pressure plate
"Recently replaced with RAM Muscle Car Performance Clutch"
New Hayes Throw-Out Bearing
New Drive shaft U joints and Yoke
New Ring / Pinion, Mosier Axles, Green Axle Bearings and seals
New Rear brakes with Lines and Hoses
New shocks with Monroe Air shocks on back
New BF Goodrich T/A Radials
New Rally 15" Rally Wheels with trim rings and Argent Centers
New Left and Right Rally Mirrors
New Carpet, Kick Panels, Sill plates
New Under Carpet Sound Deadening Material
New Door Panels
New Window cranks and hardware
New Headliner
New Window seals and felts
Rebuilt Dash Cluster
New Dash Cap
New Sony HD Radio Head Unit
New Crunch Quad Channel AMP
New 6 Speaker System
New Powered Sub Woofer Unit
New $5000 Paint job
New Duster Go-Wing
New Trunk Liner
New Marker Light units
New Rear Sway Bar (Not Installed)
