[SOLD] 1974 Plymouth Duster
7duster4
Cincinnnati, Ohio
Rating - 0%
0   0   0
I am selling my 1974 Plymouth Duster. 318/904 power steering, power brakes with disc in front. Factory A/C car. I have the parts that go with the car but the compressor is locked up.
I have owned this car since 2006. Runs very well. Has 139,000 miles. I have always kept it garaged. Tons of work has been put into this car since 2006. Here is a brief list with what's been done.
Numbers match 318 and 904 torqueflite both been rebuilt. Just about everything has been replaced in the power-train. Engine is bored .030 over. Mostly a stock rebuild except for 600cfm eddy carb, performer intake and 340 cam.
Body work and new paint in 2008. New quarter skins and rocker panels, donor fender. Base coat clear frosty green.
New duel exhaust. Many new suspension components (ball-joints, idler, pitman, leaf springs, shocks) New brakes front and back with new master cylinder. Tires have less than 500 miles (Tiger Paw 215/70/R14) with 14" Rallye wheels. Front and rear sway bars. New power steering box, u-joints, 3.21 sure-grip 8 1/4 rear.
New fuel tank and sending unit, fuel line/vent line.
New lenses, stripes, functional hood scoop, emblems. All exterior lights function as should.
New carpet, and tuff steering wheel. Interior overall in good shape.
The engine has about 12,000 miles since rebuild. Runs and sounds great. Great oil psi. Rides good and stops well for an old car. Shifts well. Zero carburetor issues, warms up quickly. Operating temp never exceeds 190.
Things that need attention:
Trans leaks fluid from the pan as well as some antifreeze looks to be coming from lower radiator hose. These leaks only happen if the car sits for a long period, such as several weeks.
The car is overall solid but there is some very slight surface rust under the left quarter.
E-brake light stays illuminated even when not activated. Also a lot of the dash bulbs are out.
Front bench seat has a couple small tears.
Bumpers are decent but rear has some pitting.
Fuel gauge quit working.
Paint looks terrific other than some minor fisheye. If requested I can send pics. May be able to sand and buff out. Color is the factory frosty green from 1974.
Selling as is with clean title. $8,000 cash. Price is negotiable. No trades. The car is located in Cincinnati Ohio.
Please PM with any questions. More pics to follow.Thanks.
More pics...
