[FOR SALE] 1975 440 Block, Crank, Rods, Pistons, Balanced Rotating assembly
SLOPAR72
Richmond, VA.
Zipcode is 23222 Richmond, Va. and price is 1100.00. Pickup only.
Block is a 1975 440 .030. It has been sitting for while and even though it was bagged you will need to clean the deck surfaces up. Main Studs also.
Crank is a Steel Standard with 6 Bolt Flex Plate Flange.
Pistons are 2295 which has a slight dome. Unsure of rings but never fired.
Factory style rod and exact type I do not know. Interested buyers with knowledge will know more about the rod type than I and this is a press fit piston/rod.
Rotating assembly is balanced and is disassembled for inspection. Done by a local mopar guy who is an excellent machinest. Bring your machinest tools with you and whomever is able to understand what has been done if you are not familiar with machining. Currently this piston is sitting around .051 in the hole so the decks have not been cut down an extreme amount. Bearings also. Clean the decks, wash it all down, and assemble it. Simple as that.
Pictures available later in the week and PM me for more info.
JW
