74Dusted
Stock Piler of 340's
Thought my '71 Demon had a 225 in it, turns out it has a 198 in it.
Here's what I know about the engine, it ran. I borrowed a set of manifolds and a carb from a friend to move the car around the parking lot. Fired it up one time, returned the intake/exhaust to my friend and the car sat for a month before I pushed it inside the garage for a complete teardown (where it's been sitting for the last 8 months or so)
I'm not putting a 6 back in the car (as my signature obviously indicates )
Engine Code (between the first 2 cylinders, near the coil, on the block) is GW198R.
Engine is still together/assembled, ugly as sin, (except the intake/exhaust that I returned to my buddy, obviously)
So here's the engine :
Told you it was ugly as sin
Anything 198 / S6 related is up for grabs (even if I don't have it listed), All items are located in Lewistown, Pennsylvania, 17044
Rods (pistons included with them) : $300
Crank : $100
Head (with valves/springs/rockers/valve cover) : $150
Block : $100
Points Distributor : $20
S6 904 Transmission : $150 (no converter, i used that converter in the SB 904 that i put in my truck)
Motor Mount Brackets : $25 for the pair (Biscuit style, not spool mounts)
uhh, that's about it isn't it? unless you guys see something you might need that is related to the /6. I'm Willing to negotiate on the prices. Smaller items can be shipped (or picked up, if you feel like dropping by and talking mopars for a while ) Larger items would have to be picked up, or you could have them shipped freight
Still assembled at the moment, if someone shows interest in a part, I'll tear it down.
Crank : $100
Block : $100
