Bogie
I hate writing this but I need to sell the Crew and hopefully quickly $3000 OBO with no engine
$3500 and you can have every Dodge part I own including the 360 I built and a second 360 block & crank
2 full power doors,
2 better fenders & a hood
Red dash
Factory Bench Seat
Set of Jungles front shackles & frame bushing mounts
Info 1984 W350 4x4 Single rear wheel short bed
Set up for 360 (no engine in it now)
NP435 trans
NP205 case
About 9" of lift 6" suspension/3" body)
37" Super Swamper SSR (rears good fronts need replacing) M/T 16x10 wheels
Dana 60 front W4.10
Dana 60 rear with Disc conversion (great lake offroad using Chevy parts)
Custom driveshafts W/1350 joints
New Centerforce clutch
Hooker Ceramic Headers
Has Hi Steer arm from BTF & new kingpins & new axle U Joints installed
Truck Needs Work
No Engine in it
Drivers floor pan is bad, rear of cab roof on passenger side was dented by a falling tree (I have a section to repair it) doe not interfere with door or show on inside of roof.
Drivers fender rolled & dented will need repair or replacement (have fenders & hood)
Passenger Door crushed vertically in the center still functions fine (have a set of power doors)
I have a 360 I built for the truck that ate a piston (out of spec)
10:1 360 .030 over Keith Black pistons
.010/.010 crank & rods with full grove mains
Melling HV pump
Double Roller Chain W/late model tensioner
Needs Cam
Rings
2 full power doors,
Red dash
Factory Bench Seat
NP435 trans
NP205 case
Dana 60 front W4.10
Truck Needs Work
No Engine in it
Melling HV pump
Needs Cam
Rings
