1985 318 with swirl port 302 heads
Mopar44134
Ohio
318 has about 100k on it. When i pulled the motor about 12 years ago for one with less miles, it ran fine, very dependable. Motor turns over fine. No carb(not FI) or distributor. Has truck mounts on it.
$250.
Willing to transport for free up to 50 miles from 44134. .50 per loaded mile after that, up to 150 miles from 44134.
Thanks,
My mom is from up there. But little to far of a drive for my as I am down across the OH river. Wish you were closer. Good luck with your sale!
would you be willing to sell the heads? if so, I'm interesed.
I know its a haul, but I thought I'd ask.
Are you going to the swap meet in Indy next month?
Was it stored in a heated garage? Roller cam?
was not stored in a heated garage but I put oil in the cylinders and ports, removed the push rods when it was stored years ago. When i posted the ad in October, I removed the plugs, motor spun freely. added more oil the the cylinders, removed the intake. The block is set up for a roller cam but someone put a flat tappet cam in it. The heads have the bigger push rod holes, lifter bore set up for factor roller. I'm at work now...I will post pic later tonight. I work til 9p.
No plans to go to Indy. Not interested in selling the heads alone(unless a nice 325 fan shroud or LCP were part of the discussion.) If I blew my 360, always figured i would drop in the 318 and run it. part of the reason why I never bumped the add. Whats the block worth without the heads.
The block is tapped for the roller lifter spider?
What's the application for that fan shroud? I might have one.
thanks!
Sorry I didnt post last night, my wife had other plans for me :cheers:
