[FOR SALE] 1995 318 Magnum block
blu340dart
MoBro. Inc.
Michigan
I have a 1995 date cast 318 Magnum block with caps. I'm not sure what the status is with this block but it looks like it was hot tanked and prepped for assembly with new freeze plugs and cam bearings. The bore size is 3.915 which I believe is stock for a 318, so maybe this was a virgin block that was never installed?? It has surface rust from sitting, how long I don't know and in the cylinders you can see crosshatch marks and looks like it will clean up pretty easy. I'm asking $150 for it and its located in Michigan. PM me here. Thanks. Greg
