Cledus
Can 308 castings support 2.02 intakes with port work
I have several sets on my race cars = They are patterned of a 308 HeadYes. There was an over the counter version with 2.02/1.60 Casting number 576 if I'm not mistaken.
They are worth 200 to 300I just tossed a pair of 308s into the scrap ben. Are they worth keeping for someone?
Thats good info especially if it turns out they needed guides. I asked the machinist about dropping down stem diameter from 3/8ths he just said it was up to me like there wasnt much gain to be concerned with so im having him put new stainless valves in i just ordered them off mancini seemed liked the best deal aroundYes. So do 1.92 Magnum valves that have less shrouding.
Just use 11/32 1.94 valves and save yourself some money.Thats good info especially if it turns out they needed guides. I asked the machinist about dropping down stem diameter from 3/8ths he just said it was up to me like there wasnt much gain to be concerned with so im having him put new stainless valves in i just ordered them off mancini seemed liked the best deal around
I figure since we're talking about valve sizes, have you seen any of the results of the experiments using 1.72 exhaust in with a large back cut? I may can see it on a W2 or the like, but am curious if the 308 or 974 head would even have enough port to use it.Money.
What's the price difference between 5/16 & 11/32 valves?
Is there a flow benefit ?
Going bigger on exhaust diameter is hardly EVER a good idea....1.6 is plentyI figure since we're talking about valve sizes, have you seen any of the results of the experiments using 1.72 exhaust in with a large back cut? I may can see it on a W2 or the like, but am curious if the 308 or 974 head would even have enough port to use it.
