2.2L Valve Spring Retainers
I harvested mine from the local bone yard. They didn't even charge me for them.
Also Hughes has some retainers that work with the magnum 8mm stem that will allow for a little more valve lift than the 2.2 retainers.
Sweet...which cars had them and which one is the eaiest to find? How did you manage to get the retainers off? They had a spring compressor there? Ill go check the yard tomorrow...thanks!
stuff the cyl with rope and figure a way to push the retainers down...
