1. 72bluNblu
    72bluNblu FABO Gold Member FABO Gold Member
    10,033
    4402
    Nov 28, 2008
    NorCal
    Local Time:
    3:41 AM
    I ran 3.55’s with 26” tall rear tires in my Duster when I had the 833. I run around on the freeway a decent amount and they still worked ok, 75mph was like around 3,600 rpm. Not crazy, not something I’d want to run for 6 hours either. But it worked ok.
    • Like Like x 1
    • Thanks! Thanks! x 1
    • ir3333
      ir3333 Well-Known Member
      4,466
      1049
      Jun 1, 2008
      ontario,canada
      Local Time:
      5:41 AM
      a friend installed 2.94's in his stock lo compression 74 360 duster along with a 904 modified with the later transmission lo first and second gears.
      said it had tremendous low end and cruised smooth on the highway with no noise or high rev harmonics.
      • Like Like x 1
      • Alaskan_TA
        Alaskan_TA Well-Known Member
        5,252
        3400
        Nov 12, 2004
        PA
        Local Time:
        6:41 AM
        In my cars, I like a 2.94 or a 3.23 with 14" tires & a 3.55 with 15" tires.
      • Slantsix64
        Slantsix64 Well-Known Member
        2,112
        770
        May 11, 2014
        SGV
        Local Time:
        5:41 AM
        3.55
        • j par
          j par Well-hung Member
          19,943
          9808
          Jul 2, 2014
          Portland Oregon
          Local Time:
          3:41 AM
          I agree on your Siri but there's also the wind noise as well to take into consideration? As the speed picks up and that a body flying Brick of hours can start a pretty good disturbance as we get going above certain speeds? Just food for discussion...
        • TrailBeast
          TrailBeast Slightly Twisted Member
          20,460
          7445
          Mar 11, 2011
          Arizona
          Local Time:
          4:41 AM
          Yep, did that and it turns out to be about 2,800 at 75mph in OD and I can totally handle that.
          Thank you for the input on it.
          The 3:55 gears are already part way done. (tore it all down and changed the ring over)
          Went to a buddies house today and pressed in the new 2" wheel studs to compensate for the discs on the original A body axles.
          I just need the large end M802048 cone, M802011 cup and the 2881041 pinion seal.
          I have everything else including a crush sleeve eliminator kit with shim selection.
          • Like Like x 2
          • 318willrun
            318willrun Roadkill '80 D150
            12,755
            12712
            Sep 13, 2013
            I'm here
            Local Time:
            5:41 AM
            lol... exact same drive train as my '76 Duster, except my tranny is stock. Low end torque is not a problem, and it cruises so nice at 60 mph going to the dragway.
            • Like Like x 1
            • thesiren74
              thesiren74 Well-Known Member
              1,056
              605
              Feb 23, 2014
              kenosha,wi
              Local Time:
              5:41 AM
              3.55 is a good choice.
              • Agree Agree x 2
              • TrailBeast
                20,460
                7445
                Mar 11, 2011
                Arizona
                Local Time:
                4:41 AM
                18 inch rims and 245/40 tires with tire height of 25 inches here, we're in the ballpark.
                Thanks
              • Garrett Ellison
                Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member
                2,213
                1707
                Jan 1, 2018
                Southwest VA
                Local Time:
                6:41 AM
                No one else has said it yet so I’ll go ahead and play devil’s advocate. If you got an overdrive, find some 4.56’s and drive something else for the high speed stuff.
                • Like Like x 2
                • j par
                  19,943
                  9808
                  Jul 2, 2014
                  Portland Oregon
                  Local Time:
                  3:41 AM
                  Then he'd have to get some drag radials and take it to the track...:thumbsup:..
                  • Agree Agree x 1
                  • Garrett Ellison
                    2,213
                    1707
                    Jan 1, 2018
                    Southwest VA
                    Local Time:
                    6:41 AM
                    I like the way you think!
                    • 318willrun
                      12,755
                      12712
                      Sep 13, 2013
                      I'm here
                      Local Time:
                      5:41 AM
                      I'd already have had it to the track in it's current state! But, that's just me... :rolleyes:
                      • Like Like x 1
                      • mbaird
                        mbaird mbaird FABO Gold Member
                        5,574
                        2532
                        Dec 10, 2005
                        boise, Id
                        Local Time:
                        4:41 AM
                        I used to think 3.55s were ideal . But with todays high speed interstates I find myself running 3800 rpms just to keep up with traffic !
                        I installed a set of 2.76s for a roadtrip and have yet to take them out. Now its a pooch on acceleration.
                        I wanna OD !
                        • Like Like x 1
                        • 69FBCuda
                          69FBCuda Life in the Fast Lane
                          1,913
                          1010
                          Aug 28, 2014
                          Florida
                          Local Time:
                          6:41 AM
                          Add a 2nd identical car that way no one would know the difference but you :rofl:
                          • Like Like x 1
                          • Garrett Ellison
                            2,213
                            1707
                            Jan 1, 2018
                            Southwest VA
                            Local Time:
                            6:41 AM
                            Seriously, though. What transmission are you using, what’s your rear tire size and what engine mods do you have. The closer to stock you are with a 1:1 final drive, the best gear for what you describe is 3.23:1.
                          • TrailBeast
                            20,460
                            7445
                            Mar 11, 2011
                            Arizona
                            Local Time:
                            4:41 AM
                            5.9 Magnum with EQ heads/1.92 intakes, Oregon cam grinders 214/224, 1 5/8 long tubes, Edelbrock dual plane, Edelbrock 600 electric, HEI ignition and distributor advance mods.
                            Trans is a 42RH overdrive with converter lockup, 2:73 rear gears and 245/40 18 Nitto Extreme performance tires at 25 inches tall.
                            Soon to be 8.25 Sure Grip 3:55 geared disc brake rear end.
                            It's obviously a top end car right now that I did a lot of interstate driving with, but in the process of making it more of an around towns car now.
                            I can put up with the higher R's on the freeways and have it quicker in the here and there average driving stuff purely for the fun of it.
                            • Like Like x 1
                            • mbaird
                              5,574
                              2532
                              Dec 10, 2005
                              boise, Id
                              Local Time:
                              4:41 AM
                              @TrailBeast
                              Is that the original color ?
                              Looks awesome !
                              • Agree Agree x 1
                              • Garrett Ellison
                                2,213
                                1707
                                Jan 1, 2018
                                Southwest VA
                                Local Time:
                                6:41 AM
                                That sounds like a happy build combination, that’s a very slick looking car! With the .69:1 overdrive and lockup, 3.55s, no question. That’s equivalent to 2.45s in overdrive, which will have you 2000 rpm at 60 and at 2600 rpm cruise (right were the torque is starting to really happen) at 80 accounting for tire growth at that speed. Happy Motoring! The 2.74:1 low will probably be a challenge for traction, but the 1.54 second will give enough rpm drop to help recover and get things rolling.
                                • Agree Agree x 1
                                • TrailBeast
                                  20,460
                                  7445
                                  Mar 11, 2011
                                  Arizona
                                  Local Time:
                                  4:41 AM
                                  Thanks guys.
                                  That is basically the original color, but repainted
                                  You got that right about first gear, as it will probably hit second about when the rear tires hit the second line of a crosswalk.
                                  It tries to break loose in second accelerating hard as it is.
                                  It's been a great car and reliable as can be, and now it's time to change it up a bit.
                                  These Nitto tires are pretty sticky, so we'll see how it does.
                                  It should leave the line in a hurry.
                                  • Agree Agree x 1
                                  • mbaird
                                    5,574
                                    2532
                                    Dec 10, 2005
                                    boise, Id
                                    Local Time:
                                    4:41 AM
                                    Same color scheme I am going with for my 69 Swinger 340
                                    484B4264-4A42-4A5F-8151-F49717B76EEC.jpeg A3DCCD5C-CD29-43DE-982A-3983DC2B265F.jpeg F9616D72-90AF-4F57-A9AA-B8A98F80C1DD.jpeg A2B10980-1CEB-4FB0-ACF1-DA294AFF2D0D.jpeg
                                    • Like Like x 1
                                    • mbaird
                                      5,574
                                      2532
                                      Dec 10, 2005
                                      boise, Id
                                      Local Time:
                                      4:41 AM
                                      Not sure how that last pic got there
                                    • TrailBeast
                                      20,460
                                      7445
                                      Mar 11, 2011
                                      Arizona
                                      Local Time:
                                      4:41 AM
                                      It wanted us to know it was a stick car.:D
                                      Something about red white and black I have always liked.
                                      I wish my interior was white.
                                      • Like Like x 1
                                      • mycuda
                                        mycuda FABO Gold Member FABO Gold Member
                                        5,397
                                        2720
                                        Feb 15, 2011
                                        Chicago/ Metro
                                        Local Time:
                                        5:41 AM
                                        2.91 change not much difference overall.
                                        Rest is on you.
                                      • mbaird
                                        5,574
                                        2532
                                        Dec 10, 2005
                                        boise, Id
                                        Local Time:
                                        4:41 AM
                                        Of course being a Swinger interior never came in white and was supposed to have a black top.
                                        But I just could not live with black during our 100 degree summers.
                                        And I like the White/ Red contrast !
                                        You understand being in AZ
                                        • Like Like x 1
                                        • Agree Agree x 1
