SgtLee511
Installing 284/484 comp cam in 340. Cam Card says 104 Intake centerline, after degreeing, I'm showing 107.5. I have a 2 degree offset, should I use the 2 degree offset or order a 4 degree offset. Final question when I install the offset, will the offset be on the left side of the crank keyway or the right side of the crank keyway?
