[WANTED] 2 sets rear boosters, 1 set primary boosters Carter AFB
Brooks James
VET, CPT, Huey Medevac Pilot
Fruitland Park Fl
Doesnt master if They are from a 400-800 CFM carb
Whatcha got ??
Also need 4 metering rod pistons, Springs and the plates on the top that hold them down
Why doesnt it matter what they came off of ?
I can tune the carb for my specific application for my engine
Its a cheat I learned from a buddy that raced NHRA Super Stock he put 750 boosters in a 500 carb, passed tech everytime
What I found
Outstanding, I’ve used worse pistons successfully , those actually look pretty good. If you have any piston springs would be excellent.
Your PayPal info and amount to send ? You could easily get everything in a small flat rate postal box at about $10
If no Paypal will a postal money order or check work ?
Thanks
Brooks
Need some parts
2. accelerator pump arm to accelerator pump "s" link
2 clips that attach the metering rod pistons to the metering rods
12 booster mountings screws
16 bowl screws
need now
1 s link
clips
8 booster screws
Let me know
Brooks
Ok,cancel the request for the other parts, I was building a 400 Competetion series that was supposed to have all the parts. . The counterweighted secondary flap is missing. The carb is fairly rare and expensive. I probably have a snowballs chance in hell of finding another one at a reasonable price. you might be thinking that I could just use another but because of the very small venturi I think it is a one off part.
