2 speed wiper motor and a 3 speed switch plug??
northeastmopar
Massachusetts
OK. I think I figured my issue. Now I need to figure how to fix it. My car came with a 2 speed wiper motor. My dash harness was toast, so I bought a nice used clean one. After doing all the install I plugged in a wiper switch I had and the motor would not work. I realized that the new dash harness donor car had a 3 speed wiper motor. I do have a 2 speed switch that now will not plug into the harness?? I do not want to change the motor to a 3 speed as I understand I will have to also change the crank arm and my car has a/c which now makes it hard to do this. SO. Is there a way I can just take the 3 speed pigtail plug and cut it off and replace it with a 2 speed pigtail plug and just drop off a wire or two and have the 2 speed wiper work? I already rested the wiper motor using the book and it appears to work fine when I jump the wires at the motor?? HELP>>>>
