Well, you see it... in the shop, primer on etc.
I have to supply rubber trim.. I had inquired a few days ago and got some sources from you all. But my question is
ARe there just 2 rubber seal pieces? The trunk seal and one that runs along the firewall area, perhaps sealiing with the rear end of the hood. It seems just be the design the '64 Dart did not have a hood seal that ran around all three sides like some cars have.
Any other rubber trim parts?
I have looked at sources and seen prices all over the place.
Had a bad experience with a trunk seal for an old Volvo that just sat up too high and the trunk would barely shut. So I want something totally correctly made that won't be a hssle for them to install.. .and then the gluing gets messy, etc.
Also there are these clips I have to get for the side spears (over 100 clips) to go back on.
Then also a small number of clips to affix the trim along the rocker panel. A source for these?
Thanks. More pix as things progress!
