scamp 408
This is a total rebuilt box with new seals all new bearings and a new 20-1 worm gear . The case the cleaned and sprayed with cast coat aluminum and looks fantastic. The box was never installed after rebuild. You can buy a heavy cast iron aftermarket one from flaming river for 550. or you can have a real mopar one for $400. from 07731
If you priced this out to do your self you would be paying more than 400 in parts plus the labor and that's if you can find the 20-1 worm gear set as they are getting hard to find.
