I have a used fuel cell that I just took out of a 70 Dart. I believe that its a 20 gallon cell but not sure who the manufacturer is. It measures 23.5 wide, 18 deep and 11 high. The outlet side has a 8 AN fitting and the vent has a 6 AN fitting. Included are the mounting brackets with the nuts and bolts. It is a steel case cell with the plastic foam filled bladder inside. It also does not have a sump. Its flat on the bottom. Id like to get $80 plus the shipping.
Ken
Edison, NJ
Ken
Edison, NJ
