[FOR SALE] 2019 Gen III 6.4 Hemi
Ronald C.
Blanket, TX
I have a 2019 Gen III Hemi, 19k miles
Long block
Not included in the price, but I do have a 6.1 intake and BBK 85 mm Throttle Body (DBC) if someone wanted the whole setup
$4500 OBO
Not included in the asking price, but I also have a 6.1 intake and BBK 85mm TB (DBC) I would part with if it helps.....
Well, I’m not really sure I know the best answer there. As I understand it, 2011 or 2012 they transitioned to a BGE block. Now that said, I think the consensus is everybody likes it better than the previous blocks. But, I can say I haven’t heard any BGE 6.4 blocks. Think this is what is used for HellCat since day one.
Does this help?
Hello, how much for the intake & throttle body each or together as a package ? Thanks, William.
Hey there, really am not to interested in selling the intake and TB unless I let go of the 6.4. If I hold on to the engine, I will likely put the intake and TB on it and use in a 74 A body build I’m doing....
So , how much would it take to get all the correct stuff to make it run right cost ???
on the front side it needs a front engine cover, water pump, pulleys, and an alternator. Topside would need to have an intake manifold and a throttlebody.
other than that it’s really going to be dependent upon what you put it in. For an old a body, it would need a standalone engine harness.
With all of that said, not very much is needed if you’re interested in doing a Gen III three Hemi swap. I am purely speculating, but I would imagine the front end accessories would probably set you back less than $300 - $400 maybe? As far as intake and wiring harness, a lot of people have went with the holly sniper set up which would probably set you back about $1500-$2000? For my build, I have been acquiring parts and pieces here and there but I am confident if I did the math, I probably do not have more than this in it excluding the cost of the engine....
would you sell block alone?...if so how much..?
Unfortunately, I don’t think I can break it out. The engine has a limited number of miles on it. If it does not sell, I will likely pilfer a 5.7 block that I have for parts, and swap it into my a body.
ok...I had to ask
