2019 summer race.... Jadaharabi vs 318willrun
who's got this race ?
  • J par - hard to beat a guy that has 4 of everything
    Votes: 7 14.0%
  • Jadaharabi - are you kidding me? this guy is working on a stock eliminator
    Votes: 23 46.0%
  • 318willrun - no plan, other than brain cramps thinking of one
    Votes: 20 40.0%
  • Total voters
    50
@318willrun
Hey buddy need your help still working on these heads on the intake side how polished do they need to be? I have alot of sanding Mark's from the stone do need to get that choppiness out?
They look alot better in person the pictures make them look dark or something
I agree, this looks a little choppy. Bowl should be more round like the seat. Always keep the Dremel moving back and forth. Don't stop and let it dig on what you might think is a high spot. As far as smoothing out the grind stone marks, I just use a sand roll on the Dremel. Don't polish the intake side.
This exhaust bowl looks good. Round and blends into the port.
The intake ports look good where the intake bolts up.
@318willrun
I thought leave the intake kind of rough for mixing Fuel and the exhaust smooth...
that's why you shouldn't "polish" the intake port. But I do use a sand roll after porting to get rid of the gritty feel. There is a fine line between turbulence and blending air/fuel.
Ok thanks I'm gonna continue working on them. How much is too much gritty? Because with the 240 grit it still leaves sanding lines. Is 240 the final drum you use??
he was right, some serious bromance going on around here. lol
I'd stay away if I were him too. lol
LOL, another instigator...
Bromance sounds pretty gay, I'm pretty secure with my manhood so if that was meant at me I'm not going to worry...
I'd give the shirt off my back for most that I talked to hear, but not my underwear LOL...
Seeing sanding marks if fine. Feeling them all "gritty" is what I get rid of. Just feel the factory casting, and see how rough that is in the intake port. Don't go for the glass look and feel. I think I use 120 grit.
on that first picture to the right it looks like the Dremel got away from you in a bit..
Yes it did!! Its was just the sanding roll luckily it's not deep it will buff out. If not completely the intake gasket should take care of it.
Porting heads at home is an art. You have to remember, the air is exiting the exhaust, so port to flow that way. Intake is obviously moving the air the opposite direction, so you have to think of the air movement that way.
The last heads I recently ported was about a 16-17 hour job just on porting for the pair.
Do yall think these head will perform better than factory or did I ruin them? Haha
It's funny when I talk to other car ppl they act so shocked that I'm porting them myself. I even had a guy on Facebook that told me I ruined a set of heads and he didnt even see them!! Lol
no, I think you've helped them breathe.
I bet have close to 20 and I'm not done!!
I have been working on them since the beginning of February. I think Feb 5th was the day I started granted i haven't worked every single day but iv put in 2-4 hours a day at least 4 times a week since then.
RATS !!!!
Not Good..... :BangHead:
Well, went out this morning to try and tune the car a little to the headers. Reached the top of first gear and oil light flickered and the engine shook with violence. I got out of the gas real quick and went to neutral. let it idle and the engine was bangin' hard on the bottom end. I limped home. engine shook like it was off balanced. Oil light stayed on when I got home and the knocking of the bottom end was loud. I'm sure I spun a main bearing.
This puts a monkey wrench into all this..
RATS
RATS
RATS is definitely a more civilized word than the one that come to my mind...That REALLY sucks!
RATS
well as much as I like to poke fun at you and say valves will fly and all that you know I'm just completely joking and this REALLY SUCKS!!!
