[WANTED] 22” Fan shroud P/N 3673821
Danco
Maine
Hi guys. Like the wanted header says.I am in search of 22 inch core Fan shroud part number #3673821
Mounting Hole dimensions left side hole to right side hole 21 7/8
Top hole to bottom hole. 13 1/8
Please no damaged ones
Thanks
Dan
Thanks Brian, I could be mistaken, from the research I did, It doesn’t look like the mounting is different
Sorry I meant to say, it doesn’t look like it would fit, the mounting is different for part number
Thanks oldmanmopar but the shroud in link is not the proper application and incorrect original part number. Thanks for trying
