shawn65
Active Member
:banghead::banghead::banghead:Just need a little guidance. I have a 225 /6 and I have new plugs, wires, points, and cap. She starts up good and drives fine. Now here is where it gets a little weird. When she is warming up it sounds like there is a miss. When youre driving its fine. But at the stop light you can hear it and see it in the tachometer. If I drive to the store or something and start the car it then sounds like its starving for fuel. I checked the timing which is at 5 degrees BTDC with vacuum advance off....with vacuum advance Im at 25 degrees. I believe this is correct. Checked all wires and plugs which are good... adjusted the points as best as I could replaced the coil, condenser, (inside the dist and at the coil) Im still having this miss...any ideas:banghead::banghead::banghead:
