225/60-15 All Around?
bordin34
Active Member
Mahwah,NJ
I just got some 15x7 mopar steel wheels and want to put 225/60-15 tires all around on my 74 Valiant. The car is stock with front disc brakes and a 7.25" rear. Will they rub up front?
Not sure if they will rub or not since I do not have a Valiant but here is a link that you can use to put the stock tire size on one side & the new size on the other. It will tell you how much taller, wider & if it will cause problems along with how it will change your speedometer reading.
http://www.rimsntires.com/specs.jsp
Thanks, I searched the forum and it seems that some rub and some don't. I dont know if its the extra width from having disc brakes that makes a difference.
That's what I'm running on the front of my 1973 duster. thay are close but thay don't rub
