446acuda
'81 or so cast crank 225 slant 6 that started out as a hydraulic cam truck engine then was put in a car with a stock solid lifter cam. Removed due to excessive blowby. Standard uncut crank and standard bore. Head casting number is 4095778, block only has the casting number that is in the pictures. What is you see is what is included. $75 local pickup only in Statesville, NC.
