Bought the Valiant real cheap to have it as a daily driver and planned to put the Valiant front on my 73 Dart Swinger and put the Dart front on the Valiant. But I have fell in LOVE in my Valiant and especially because it has a 225 Slant 6 (Still in love in my Dart and the V8 too). Don't think I'm going to change fronts between them since I like the look to much on the Valiant that I don't want to destroy it with the Dart 73 beak front. The plan is to fix small things on the Valiant bit by bit so I have something to drive under my Dart restoration. My goal for now is to get decent fuel mileage from the Slant. And I think is going in the right direction since my mpg is between 19 - 26 now. That was achieved by change from the Holley 1920 1bbl to a 318 Carter BBD 2bbl. Found the intake manifold for sale at a site and the carburetor and air cleaner was from my Dart. Made a new linkage to the 1bbl kickdown linkage to work with the Carter BBD. The shift points is exactly like it was with the 1bbl Holley and sometimes the third gear can feel like second gear when accelerating. It has much more power now! Going to restore this Valiant with as little money as possible since I need the money to my Dart for now. But if I know me right I'm going to spend money for a better life for my 225 Slant and the Valiant. Really like the Slant with its combination of power and MPG and the sound it now makes with my new exhaust is real good. People always first think it's a V8 when my Slant idles. Most people would probably think the cabin sound is to loud but I love it since I think old car should not be all about comfort and I thrives in that sound it makes ( Been driving it for 2000 miles like this). It feels real and definitely not like the newer boring cars. I took my Valiant to a car show and it was a 4 hour drive and it was loud in the end but I still had fun and took the 4 hour drive back home the day after with a smile on the lips. It was a ringing sound in my ear awhile after. But I still don't want to tone down the exhaust sounds. The clearcoat is peeling of and it have some dents and rust on the body panels but the subframe is in real good condition and have no serious rust. Which got me by surprise since my Dart and my friends 2 Valiant's was rotten in the same places and my Valiant has no serious rust anywhere on the subframes, floor and trunk.
Made a new exhaust system.
Much better than the old side pipe that was there before.
Got a good deal on the intake.
The arrangement for good MPG and power. The Carter BBD is rebuilt and I rebushed the throttle shaft but I failed with the alignment and I needed to grind the bushing to make it fit. Now is the throttle shaft looser than before so I'm waiting for a better used throttle shaft base plate to arrive with the mail.
Made a manual choke.
Soldered together a more modern voltage regulator to the instrument cluster.
Installed a Ignitor with matching coil. Also change rotor cap and spark plug wires that have resistance and are suppressed. New NGK ZFR5N spark plug was installed with a .044" gap and the ring washer removed.
Going to install a EZ-wiring kit harness in the future. Since I don't like the wire routing with bad wires that are spliced here and there.
