245/60 R14 on a 75 Scamp
roadrunnerh
Pittsburgh, PA
Ok fellas, my plan is to run 215 70 14's on stock 14x5.5 rally wheels on the front and Wheel Vintiques repro 14 x 7 rallys in the rear with 245 60 R14's.
Will I have a rubbing issue in the rear? 1975 Scamp, 8.75 rear stock XHD spring location.
Should work fine! That's exactly what I had on the rear of my '73 with plenty of room. I have 225 70 14's all the way around now
no problems at all ... took my 245/60r14's off and put on 255/60r15's ... look WAY better than the 14's did !! ... 4.25" backspacing by the way ....
What is your rim size (14x?), and what is the offset, if any?
I have 14x7's with 0 offset, and I was wondering if the 225-70-14's would fit OK on my 64 Valiant (w/stock 7 1/4 rear and stock springs/locations).
Thanks!
Well guys, I installed the 14x7 with 4.25" backspace, with 245 60 R14's on my Scamp and I love the look! No rubbing and plenty of room. :blob:
