255/60/15 alternative?
MOPARJ
What can I upgrade now?
Thousand Oaks, Ca
Currently running 255/60/15 on 15x7 Torq Thrust Ds. What other size is very comparable, with little to no variance in height or width? Looking for a tire size with a few more options than Cooper Cobras or BFGs.
Who sells Kelly Charger RWL online?
Yup, that's about it. 255 is the width in mm, so if you want the same width it has to be a 255. 60 is the sidewall ratio, ie, the sidewall height is 60% of the width. You can get the same height with a different width and ratio, but if you want the same width you need the same ratio. As for availability, yup, not much out there in 15's anymore besides BFG T/A hockey pucks and the slightly better (IMO) Cooper Cobra's.
Mickey Thompson sells Sportsman S/T radials in a 255/60/15. Their Sportsman S/R radials come in 26x10x15 or 28x10x15, so, either 1" shorter or 1" taller in the same width as 255/60/15 (27" tall and 10" wide). The do sell their ET Street S/S tires in a 27x10.5x15, those are a DOT approved street/strip tire. And the section width is listed at 10.1", so, it's really the same width as a 255. They also sell their ET street R in that size if you're really not worried about anything other than dry traction, those are also DOT legal but just barely. They would not be a good choice for cold or any kind of wet weather.
