[WANTED] 273 BLOCK
i've got a 273 from a 67 barracuda sitting in the garage since pulled , was keeping it around for the rocker gear . it complete long block assembly . i'm in calif also .
there you go , i'm in san jose . but there is a member closer to you then me . if it don't work out just pm me .
Hi is it in good shape I'm in hemet ca , how much
Is it .
273 ball
273 ball , the whole long block less valve train , 250 ( block crank rods heads pistons pan valve covers timing cover ) . you have been offered blocks for less . but this one is pan up the two bbl intake . it was a running motor before garaged stored .
