[WANTED] 273 engine for a 66 barracuda
I have a 273 out of a 67 dart complete from fan to clutch carb to oil pan you will need an alternator. Has about 5000 miles on the rebuild. Have all the paper work? If you are interested pm me. Will not be home until Monday.
I am looking for a 273 engine for my barracuda
I have a '66 formula S 273 4-bbl and located right in CT.
Needs rebuild but complete intake to oil pan with valve covers, distributor and exhaust manifolds. $300
I got mine in a deal for a 66 cuda i just bought. I can t tell you many details other than it spins, its cometenand the car odometer shows 17,000 miles, so probably 117,000! Needs a rebuild....$150, and im in michigan near Ann Arbor. Geof
Got a late 65 dated 273 out of 66 barracuda. 2bbl motor. Complete from pan to carb. including exhaust manifolds. Was running good when pulled 8 yrs ago but I would pull apart and check her out where it has been setting so long. Open to reasonable offer
I have a '66 formula S motor, I think it's from a K code vehicle. No intake manifold or valve covers but rest of motor is complete. Needs complete rebuild.
