Where can I get piston ring set?
Bore is 3,630" with standard 3,625" rings there is too much cap.
I would like to find correct size ring, can someone help or give a good advice.
I am now rebuilding my 67, 273 , 4bbl, 4 speed engine. Pistons are original, in good shape, cylinders are good as well.
I am assembling new main bearings, new rod bearings, new oil pump, new timing set,comp cam CCA-CL20- 221-3 with hydraulic lifters, and new valve springs for 84 lbs.
It has been my daily driver.
Lets hope that it's worth of money.
Plese give your comments.
