I could really use someones expertise with rocker shaft intallation on my 67 273 engine. I am trying to install my rockers onto the shafts, then the shafts onto the heads.
The FSM says " Install rocker arm and shaft assemblies with notch pointing to cenrerline of engine and tword front of engine on left bank and to rear of engine on right bank " first off :
1. I assume right and left is from sitting in the drivers seat ??
Then:
2. should the notch be at the top or bottom of the shaft ??
I guess If I knew the answer to these questions I can figure out the rest - does anybody know this info or where I can find it.
Thanks Alot, Bill
Then:
Thanks Alot, Bill
