273 rockers on Edelbrock heads
roachmech
Active Member
California
I installed a set of Mopar Performance adjuster screws (with the required mod fro the lock nut )
on my 273 rockers and mocked up on the heads .
You can see the rocker tip sliding off the valve stem at full lift (501") NOT OK
I installed a set of CCA-621-16 .080" lash caps fronm Summit and checked it again. Not perfect but I am gonna run it.
Do you have a part number for the Mopar Performance adjuster screws and lock nuts?
They definitely did correct the geometry
A better way to go would be to machine down the rocker saddles or maybe buy better rockers.
I’m not going to argue with you, but you did not correct the geometry.
To correct the geometry you need to move the shaft UP and AWAY from the valve. You didn’t do that. That is the only way to get it right. A lash cap doesn’t correct the geometry.
If you look at your picture above, you can see how close the rocker is to the retainer. The OD of your spring is most likely not 1.550 or bigger.
When you see that you know the geometry is off.
Did what you do work? Yes. Is your valve train happy. Absolutely not.
Like I always say, b3racingengines.com has four very good tech articles on this.
I wish we could download them here and make a sticky for them.
It would save a ton of grief.
BTW, just to nip it in the bud, using a beehive spring for more clearance doesn’t fix geometry either, because that comes up almost every time this situation occurs.
I keep saying the same things. I just had a guy in another thread have a revelation and is now in contact with Mike. All we can do is keep saying it. Here’s Mike’s tech pages.
B3 Racing Engines LLC - Mopar Rocker Arm Geometry Tech
It just gets old. And if you don’t kiss *** and sweet talk people you’re an asshole.
The OP already did his rockers.
I’m hoping to stop the other guy from making the same mistake.
You’re a prick if you do and a prick if you don’t.
I know. It was the exact same argument I made elsewhere but this time he went and read, and learned, and is correcting the geometry instead of grinding on rockers for clearance. That was rewarding.
