roachmech
Active Member
I installed a set of Mopar Performance adjuster screws (with the required mod fro the lock nut )
on my 273 rockers and mocked up on the heads .
You can see the rocker tip sliding off the valve stem at full lift (501") NOT OK
I installed a set of CCA-621-16 .080" lash caps fronm Summit and checked it again. Not perfect but I am gonna run it.
