273 Stock Eliminator Heads
A/MP
NHRA lists 3 serial #'sfor the '65 A body w/ 273. Does anyone know what head flows the best? Thanks Tom
Were you thinking about running it as a 180hp or a 235hp? If you are going to run it as a 180hp you will have to run the "315" head because NHRA lists the '65 intake which will only match the '65 head without modifications. I was going to convert my bracket car into a stock eliminator car and I was going to run it as the 180hp version. As far as head flow it didn't matter to me because the 2 barrel carb will flow less than the any of the heads.
Chuck
