2bl to 4bl
river rat
Houston, TX
i'm going from 273 2bl to a 318 4bl and want to understand what is required from a throttle linkage perspective. I have the bracket already that goes on the back of the manifold, what else do i need? The new 318 has a eddy carb on it.
if you have all the 273 stuff you should be able to use that with little modification.
That's what it looked like to me, just wasn't sure in the long run how effective that would be.
it will be as good as factory as long as you get full adjustability and no binding or hanging up.i always start my adjustment at wide open throttle,the lever on trans all the way back...then drive it and see how it does.also i usually get a throttle bracket(1481 for edelbrock/20-7 for holley)that is usually 8$ well spent.
