Part two of the Indy swap parts. This is nice "489" case with factory 3.55 gears. Was an open but has a brand new clutch type sure grip and bearings. Has the solid spacer so you can swap on a 7290 series yoke if needed and not have to mess with the whole crush sleeve deal and does have a new pinion seal also. Putting it out there at $650.00 unless some one buys the rear end with it first.
