[FOR SALE] 3.79 Stroke 340 Main Forged Rotating Assembly
Rocket
CT
I have a nice small block stroker 340 main assembly consisting of a Mopar Performance 3.79 stroke forged crankshaft, Wiseco 4.080 bore flat top pistons and 0.927 pins, Childs & Albert Duramoly rings featuring gapless second ring, K1 6.125” H beam rods. All parts are new except the crankshaft. All parts are forged. The crankshaft is fresh from the machine shop. It was cleaned, magnifluxed, checked for straightness and the throws were indexed. Mains were ground 0.011 undersized and the rod throws are standard 2.100 small block Chevy size. Pistons are 1.565 compression height. The pistons were sized for the pins and were assembled and placed in a block with a different rotating assembly in the past. I changed direction and disassembled the short block. Pistons show minor markings from the assembly and disassembly process on the skirts. Assembled, the assembly will be right around 9.585” for a zero deck height. Add bearings and balancing and it is ready to go.
Price is $1,850 plus shipping to the lower 48 states. I can ship internationally for the additional cost.
PM with any questions or for more pictures.
Compression would be 11.1 at 0 deck height and a 0.040 thick head gasket.
PM me if you would like to discuss further.
Thanks
