[WANTED] 3 speed shifter for 71-74 b-body
I have one but not sure what it's for if you provide some specs on important info I can check it out and/or provide picture
Honestly I'm not sure what it looks like. My car is a factory 3 speed car, the shifter and 3 speed trans were gone when I bought the car. I'm looking to put the 3 speed back in it.
all the mechanisms are the same but the handles are different from car line to car line.
I have a B/E body handle. ...but only the handle because I used the mech. in one of my A-bodies already
on the left is a 3 speed shifter for an A-body ...on the right is one from an E-body which should be the same as a B-body (71-4)
the mechanism is the same across the board and will bolt up to either handle. The handle is different and the shift rods will be different as well (b/e body ones are longer)
The handle on the right for B/E body is available
What do you want for the b/e body handle?
