[SOLD] 302 cylinder heads
MObarracuda
MO
Rating - 0%
0   0   0
pair of 302 SB 318 Cylinder heads reworked from Machine shop. Installed them this spring on an old 273. Found a 340 this fall to replace the 273. Time for them to go. Paid extra $80 bucks for light port work in the bowls. Has small valves with 3 angle valve job, magnaflux, seals, and surfaced. head bolts not included and no rocker arms.
I have Machine shop invoice to support the AD. Heads are in Springfield MO.
Price is $650 for the set + freight. Will deliver for the asking price within 60 miles by appointment. pictures shown just before and after initial install and trial.
Tags: swril port, small block, mopar, Barracuda, dart, dodge, d100, Dakota, chamber, 57cc, 318, 360 dart, barracuda, duster
Not understanding the white smoke? Where the heads checked for cracks?
Yes, heads were cracked checked. I miss diagnosed the low compression condition on the 273 thinking it was the heads. I installed the reworked heads on a motor with 138,000 miles. After I installed the new heads the rings could not hold the compression. The compression numbers improved some but it started burning oil.
Thats a better understanding
550.00 is a great deal for these heads they should sell fast
