308 Bearing Part Numbers - Looking for a Max Bearing
the_cuda_guy
www.cuda-challenger.com
Hello, I am getting ready to rebuild my 1976 - A833 OD (cast iron case), it is going behind a RB. Does anyone here have a 308 bearing listing for part numbers that are compatible? I have read that SKF and Timken are the best brands to buy etc. but from what I can tell they do not offer a 308 max type at this time or its not easily findable after much internet searching.
Here is the max bearing that I found, but it is not SKF or Timken or brand I am familiar with:
Consolidated Bearings 308-ZZNR - This is a 308 max type bearing, with a snap ring groove.
Has anyone used Consolidated for their trans? I understand that they rebranded from many other countries manufactures and Consolidated does not manufacture any bearings themselves.
Is there another max type bearing out there? This is a max effort rebuild for power and durability etc.
I have searched the internet extensively and made a couple calls, no joy.
At this point I do not want to bother Mr. Passon or Mr. Brewer as they are in business and not an information service.
If I cannot rule these bearings at the link above out or another bearing in, I may call them and get their thoughts.
Thank you, for any help or insight,
Don
Edit: I found these SKF on amazon:
No amazon results came up in my AI searches.
Are these the SKF Max that I have seen referred to on this and other sites?
I was hoping to not bother him and Mr. Passon, I was thinking these answers would be a little easier to find LOL! I will see what the community has to offer and then reach out to them.
You are welcome to email me with questions anytime. Good luck in your search, but what you will find is that your only option for buying a new bearing is going to be a standard 8 ball import. USA made 308's have been gone for probably 15 years now. Are there still a few new ones around? I'm sure somewhere....I have a few left...and I'm sure there are a few here n there on a dusty shelf.
Thank you for the reply and the offer! I will take you up on it, as I am set to do this myself with good parts.
The bearing search is going on day 3 and I have found exactly what you said. Not offered new and I would need to find some older production/new Max types that would work. Along the way I have learned an insane amount about bearings and what the coding's mean and the applications etc.
I don't understand what makes a "max bearing" a " max bearing".
My understanding for this application that a Max bearing is a 9 or 10 ball bearing
My understanding is compared to a normal bearing from the factory, these bearings will have an extra ball or balls for strength; hence the term max bearing because that housing has the max number of balls/rollers that will fit in it. This is knowledge I got from research on the internet so take that for what it's worth.
Don
Normal 8 ball bearing on the left, 10 ball on the right.
