318 2bl vacuum hose diagram
jwh70valiant
Ohio
Does anybody know where I can find a diagram for the vacuum hoses of a 318 2 barrel. I have a '72 Duster that is running very rough after winter storage, and need to hook up the vacuum hoses the way the factory intended them to be. Thanks!
A factory service manual is going to be your best bet, but if you have a factory 2bbl, I can go out and look on my car and tell you where most of it goes.
You may also want to take some pictures of what you have under the hood and post them.
I know the routing of the BBD Carter carbs pretty well on most years and applications.
There could also be a couple of other sources of vacuum leaks, even if your hoses are routed properly, like the condition of the hoses and ends, themselves, the PCV valve, brake booster hose, the booster itself or the hose to booster fitting and grommet seal (if equipped), etc.
