318 340 360 408 aluminum water pump
Stroked408
Bay Area California
8 blade aluminum water pump, never used. Fits small block 318 340 360
$75.00, with free shipping, shipped via USPS Priority Mail
Located in Northern California, just south of Oakland.
Not sure what year as it was purchased brand new. The part number on it is 30823-1. Most likely early to mid 70's.
I show
Dodge Chrylser Aluminium Water Pump fits 1975 to 1988
Should work for any small block from 1970 up until the time they switched to the serpentine drive. Would work on the earlier engines but the inlet from the radiator is on the wrong side & the snout is longer so the pulleys won't line up unless you switch all of the pulleys on your engine to the 70 & later style. Also the radiator hosse will hide the timing marks on the earlier engines.
